funglenn
Feb 12, 2017Luminary
Help /dev/md0 is full
Help, my primary parition is filling up--it sent me an email and this is what I see: What is the /dev/md0? root@ReadyNAS:~/VirtualBox VMs/Windows10_64/Logs# df Filesystem 1K-blocks Used Availab...
funglenn
Filesystem Size Used Avail Use% Mounted on
udev 10M 4.0K 10M 1% /dev
/dev/md0 4.0G 3.5G 157M 96% /
tmpfs 1.9G 24K 1.9G 1% /dev/shm
tmpfs 1.9G 6.2M 1.9G 1% /run
tmpfs 959M 0 959M 0% /run/lock
tmpfs 1.9G 0 1.9G 0% /sys/fs/cgroup
/dev/md126 7.3T 4.6T 2.7T 64% /data
/dev/md126 7.3T 4.6T 2.7T 64% /home
/dev/md126 7.3T 4.6T 2.7T 64% /apps
funglenn
Filesystem Size Used Avail Use% Mounted on udev 10M 4.0K 10M 1% /dev /dev/md0 4.0G 3.5G 157M 96% / tmpfs 1.9G 24K 1.9G 1% /dev/shm tmpfs 1.9G 6.2M 1.9G 1% /run tmpfs 959M 0 959M 0% /run/lock tmpfs 1.9G 0 1.9G 0% /sys/fs/cgroup /dev/md126 7.3T 4.6T 2.7T 64% /data /dev/md126 7.3T 4.6T 2.7T 64% /home /dev/md126 7.3T 4.6T 2.7T 64% /apps ilesystem 1K-blocks Used Available Use% Mounted on udev 10240 4 10236 1% /dev /dev/md0 4190208 3668688 160432 96% / tmpfs 1963928 4 1963924 1% /dev/shm tmpfs 1963928 6324 1957604 1% /run tmpfs 981964 0 981964 0% /run/lock tmpfs 1963928 0 1963928 0% /sys/fs/cgroup /dev/md126 7789422656 4918553848 2863483208 64% /data /dev/md126 7789422656 4918553848 2863483208 64% /home /dev/md126 7789422656 4918553848 2863483208 64% /apps yes, but how do i find out what to remove?
- funglennFeb 12, 2017Luminary
i found the one VM snapshot--deleted the 1.6G file and the system went from 88% to 45% full.
crisis averted!
thanks all
- bedlam1Feb 12, 2017Prodigy
AFAIK 45% is above average usage, have a look at the posts shown under "recommendations" to the right of your initial post for advice on finding more culprits
