Ashj68
Jun 29, 2023Aspirant
Help! I can't browse the webpage of my ReadyNAS Duo V2
Hi all. Hoping someone may be able to help me please? I'm trying to browse the Admin/Device Page of my Duo V2, but am getting the following error: This site can’t provide a secure connecti...
Ashj68
Jun 30, 2023Aspirant
Hi Stephen,
Thanks for your suggestion.
I've only been able to get so far with the Firefox aspect, as I'm now trying to sign in but unfortunately, it doesn't appear that the login credentials I think I used initial are correct.
You don't happen to know if there's a way to force a reset on the Username and Password (without doing a full factory reset which, I think, wants to wipe the drives) do you?
Thanks in advance.
Ashley.
Jul 01, 2023Guru - Experienced User
The username has to be "admin". The default password for the account with the Duo v2 is "password"
An OS reinstall will reset the password back to the default. It will also reset the NAS to use DHCP (likely it is already). Instructions are on pages 16-17 of the hardware manual here:
The OS reinstall will not harm your data. The factory default will, so be careful not to do that by mistake.
BTW, 5.3.7 firmware is rather old. After you regain access, you should update it to 5.3.13 (The final firmware for your NAS).
