JGwartney
Jun 08, 2022Aspirant
Help my OLD READYnas drives are Not Recognized.
I've searched the forums and I can't seem to find a solution, so here is my situation. Over 15 years ago I purchased an Infrant READYnas X6 (RNX6-DLS) version B. I installed 4 - 500GB Seagate dri...
Jun 09, 2022Guru - Experienced User
JGwartney wrote:
After plugging in the READYnas x6 all drive lights are stable and seems to be operating as it should. It is directly plugged into the switch using a Ethernet Cat 6 cable that is plugged into the wall and back to the Modem/Router.
Are you also seeing the correct LED status for the ethernet connection?
Do you recall if the ReadyNAS was configured to use DHCP? Or was it configured to use a static address?
There are some other barriers here:
- Safari (like other browsers) recently dropped TLS 1.0 support, so the HTTPS access needed to get to Frontview will fail. There is more info on this here: https://community.netgear.com/t5/New-ReadyNAS-Users-General/Workaround-for-ERR-SSL-VERSION-OR-CIPHER-MISMATCH-problem-for/m-p/2198243
- I believe MacOS dropped support for CIFS/SMB 1 some time ago, so you will need to make sure that AFP is enabled on the NAS (and I guess also the Mac).
If the NAS has a static address, it is possible to do an OS reinstall from the boot menu. That will reset the network settings to use DHCP, and also will reset the admin password back to factory default - either netgear1 or infrant1 in your case. Data should not be affected.
JGwartney
Jun 09, 2022Aspirant
Thank you StephenB for your guidance...
- Yes, the ethernet lights all all green and seem active at the backside of the READYnas and NETGEAR switch.
- It's been so long I'm not certain, but it is possible that I assigned a static IP address 15 years ago. No idea what it could be though.
- Safari (like other browsers) recently dropped TLS 1.0 support, so the HTTPS access needed to get to Frontview will fail. There is more info on this here: https://community.netgear.com/t5/New-ReadyNAS-Users-General/Workaround-for-ERR-SSL-VERSION-OR-CIPHER...
- Thank you. I'll read into it here and see if I can't find a solution using Firefox perhaps? - I believe MacOS dropped support for CIFS/SMB 1 some time ago, so you will need to make sure that AFP is enabled on the NAS (and I guess also the Mac).
- I'm not sure how to do that since I can't log into the NAS at all. I'll research a little more about how to do that with my MAC though.
- https://kb.netgear.com/24874/How-do-I-access-the-boot-menu-on-my-ReadyNAS-Duo-NV-NV-X6-or-600
- - I'll look into this also to see what I need to do "reinstall it from the boot menu" of the NAS.
Thank you again for your help.
Jeff
- StephenBJun 10, 2022Guru - Experienced User
You could try installing RAIDar 6.5, and see if that will find it. https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar
Not sure if that will work well on an M1 though.
- JGwartneyJun 11, 2022Aspirant
Hmmmm... it's asking that I install:
NETGEAR RAIDar Installer
NETGEAR RAIDar requires OpenJDK (version 11 or higher) or java (JRE version 7 or higher) to be installed on your computer.
Please visit www.java.com or openjdk.java.net to install java before opening RAIDar.
I installed java on my windows machine and it still didn't allow it.Is this necessary? I don't really want to install java if I don't HAVE to.
Jeff- StephenBJun 12, 2022Guru - Experienced User
Please visit www.java.com or openjdk.java.net to install java before opening RAIDar.Did you download version 6.5? Or the older 4.3.8?
