bnwdandy
Sep 16, 2013Aspirant
Help! One of the rear USB is not responding
Hello, I have ReadyNAS NV+ RND4000 unit, there are 2 USB ports at back, bought it on 2010 Christmas. I recently bought a UPS and try to plug it in along with my printer at back. Found out the bottom ...
fastfwd
Sep 16, 2013Virtuoso
bnwdandy wrote: I have ReadyNAS NV+ RND4000 unit, there are 2 USB ports at back, bought it on 2010 Christmas. I recently bought a UPS and try to plug it in along with my printer at back. Found out the bottom USB is not responding.
I cannot help with the broken port, but you can work around the problem: Just plug a powered USB hub (with an external power supply) into the other port and then plug all your devices -- flash drives, UPS, printer, etc. -- into the hub.
