bnwdandy
Sep 16, 2013Aspirant
Help! One of the rear USB is not responding
Hello, I have ReadyNAS NV+ RND4000 unit, there are 2 USB ports at back, bought it on 2010 Christmas. I recently bought a UPS and try to plug it in along with my printer at back. Found out the bottom ...
vandermerwe
Sep 17, 2013Master
If you get a replacement unit you should be able to just move your disks into the new unit while its off and you'll be ok. Note it's advisable to set up the new unit with a spare disk first and get the firmware updated, then power down and insert your old disks.
For a small fee you can get an advance RMA unit to minimise downtime.
