woto
Dec 26, 2015Aspirant
Help! ReadyNAS 104 Transfer rate
Hi Guys I wonder if someone can help me please. i have just got a ready nas 104. i have 2 WD Reds 4Tb installed in it. Running the latest firmware on the NAS. my transfer rates seem a bit slow, ...
JennC
Dec 26, 2015NETGEAR Employee Retired
Hello woto,
Welcome to the community!
May I ask what firmware version are you running on the NAS?
If you have AntiVirus enabled, try disabling it and see if the same performance.
- wotoDec 26, 2015Aspirant
Hi
thanks for your reply. I updated the firmware and the software today to the latest version.
i don't have any anti virus running.
- JennCDec 26, 2015NETGEAR Employee Retired
Hello woto,
I suppose that is 6.4.1
Do you any other app running on the NAS?
Please also try turning SMB off then on and see if the same slow performance.
There is also 6.4.2-T59 (Beta 1) available that you can try.
Ok thanks will give that a go. Will let you know how it goes
