woto
Dec 26, 2015Aspirant
Help! ReadyNAS 104 Transfer rate
Hi Guys I wonder if someone can help me please. i have just got a ready nas 104. i have 2 WD Reds 4Tb installed in it. Running the latest firmware on the NAS. my transfer rates seem a bit slow, ...
woto
Jan 02, 2016Aspirant
Hey
Just to let you know, sorted the problem. Did a lot more testing with laptops and PCs that I get hold of, I was finding a pattern and its Windows 7 is slowing it down, as some of the tests I did were on Windows 10. So I upgraded mine to 10 and now I am getting around 68Mb/s that's mapping a network drive so I think it's using SMB protocol but if I transfer using FTP with FileZilla I only get 15Mb/s
So I presume that's the fastest it will go. I also tried connecting a USB3 to it and transferring the data using the web portal but unfortunately it doesn't say the transfer rate, I don't suppose any one knows that speed ? I do know the speed of USB3 but it does very from device to device.
Regards
woto
Regards
woto
BrianL2
Jan 02, 2016NETGEAR Employee Retired
Hi woto,
Thanks for the update and we're glad that you have finally sorted out the problem. Anyway, you can measure or check the transfer speed when transferring files from your PC to the attached external USB hard drive on your ReadyNAS if you will do the transfer via File Explorer (drag and drop procedure). You may also want to create a backup job (found on the admin page) and it also transfer files in a faster manner.
Let us know if you have further questions.
Kind regards,
BrianL
NETGEAR Community Team
