daveproctor
Sep 23, 2015Aspirant
Help with how to replace a failing disc
My ReadyNAS has been running for a long time now with 4x 2TB drives in an X Raid configuration. I am getting warning messages which indicate that one of the drives could be about to fail. Is re...
Sep 23, 2015Guru - Experienced User
Can you tell us what the errors are?
daveproctor wrote:
Is replacing this as simple as taking out the old drive, installing the new one and letting the ReadyNAS set up the new drive?
That is the procedure (hot-removal and then hot-insertion). But back up your data (at least the most critical) before you insert the replacement. Sometimes drives fail in rapid succession, and the resync will stress the remaining drives.
- williehowardSep 27, 2015Aspirant
Interesting that someone else has experienced a failing disk in a two disk ReadyNas Duo system. I just ordered two new drives after getting three successive messages that one of the disk was failing. As soon as the disks arrived, I inserted one in drive 2 and the unit began to sync the new drive with the old in drive 1. I went to bed because I knew it would take 3 or 4 hours to complete the transfer. Had two 500GB drives installed.
To my surprise the next morning, the unit had come to a complete halt. I removed the new drive and tried to restart the NAS with only the old drive in bay 1. It never came back up. When I run the Raidar, it reports that there is a bad root sector. To my dismay, I had over 5 years of photos taken as a professional photographer loaded without a backup. Now it looks like I've lost all of the photos. I purchased a disk salvage program and let it run to extract data found on one of the drives and it took 5 hours to go through the drive extracting my photos. It did extract the images but none had meaningful filenames, the folder structure was non-existant and all of the photos were fragmented. Bottom line, the extraction performed by the salvage software was useless. Now I'm trying to get a refund for the salvage software.
Since the ReadyNas Duo V1 is over 4 years old, I can't get any support from Netgear. I'm not pressing Netgear to repair the drive but I would like to get my precious photos and move them to another storage device. I always though I was safe with RAID storage because of it's built in redundancy but now it looks like it's easy to lose information when the RAID Management software fails, becomes unsupported and is proprietary.
- StephenBSep 28, 2015Guru - Experienced User
FWIW The raid is not proprietary (xraid is built on top of standard raid).
Try linux reader (http://www.diskinternals.com/linux-reader/) in a windows PC (connecting disk 1 with SATA or USB).
If you don't see the C partition, then try the other disk.
- williehowardOct 01, 2015Aspirant
Thank you for your suggestion on Reading and Extracting information from my NETGEAR drives. I tried your suggestion by inserting one of the two drives in a SATA case connected via USB to my desktop Windows computer running Win 7. Using the linux tool you suggested, program was able to "see" the drive but was unable to open its files. For some reason, it seems like the NETGEAR system corrupted the root file system on the disks because when I initialize spare disk units in READYNAS Duo drives 1 and 2, both start up, initialize and the partitions are accessible from Windows. But when I replace the newly initialized drives with my old drives, the ReadyNAS Duo will not read them. I even upgraded the NETGEAR OS Firmware to version 4.1.14 and I was still unable to read the disks.
I'm wondering if NETGEAR will allow me to send them one of the drives so they can repair the root segment well enough to read the disk content while preserving the Windows file structure. My goal is to extract the more than 15,000 photographic images from the drives. I never backed up the RAID to other disk media because I always thought that I had protection on the mirrored drive and the likelihood that both disk would fail simultaneously, was nonexistent. What I did not know was that the weak point was the possibility of a corrupted file system on both disks.
- daveproctorOct 02, 2015Aspirant
Sorry for not picking up the replies here - I am getting this message
Reallocated sector count has increased in the last day. Disk 4: Previous count: 312 Current count: 314 Growing SMART errors indicate a disk that may fail soon. If the errors continue to increase, you should be prepared to replace the disk.
[Fri Oct 2 04:00:07 WEST 2015]Also this on Smart+ information:
SMART Attribute Raw Read Error Rate 0 Spin Up Time 983 Start Stop Count 105 Reallocated Sector Count 314 Seek Error Rate 0 Power On Hours 39928 Spin Retry Count 0 Calibration Retry Count 0 Power Cycle Count 103 Power-Off Retract Count 102 Load Cycle Count 2068382 Temperature Celsius 36 Reallocated Event Count 249 Current Pending Sector 935 Offline Uncorrectable 340 UDMA CRC Error Count 0 Multi Zone Error Rate 4681 ATA Error Count 0 Extended Attribute Hot-add events 0 Hot-remove events 0 Lp stat events 39 Power glitches 0 Hard disk resets 0 Retries 0 Repaired sectors 0 - StephenBOct 02, 2015Guru - Experienced User
[Fri Oct 2 04:00:07 WEST 2015]I'd replace this disk.
