sdouek
Sep 30, 2016Guide
Help with my readynas need support
OK so I have not been around for a while car accident. Any way I haven't been able to keep up on my readynas pro business edition. Thursday a hard drive failed. I put in a new one and it rebuild i...
- Oct 01, 2016
Your volume is not redundant (only four out of six disks in RAID-6)
/usr/local/crashplan is 2.8GB though. It has filled the 4GB root volume.
sdouek
Oct 03, 2016Guide
Thank you mdgm, for helping me and for Stephen B for pointing out that crashplan yet again has gone wild and and filled up my 4Gb Root Volume, I had no idea it could go so wrong, not only did Crashplan fill my root but I suspect it also caused the 2 new hard drives I used to rebuild the nas to fail.
The system is back up and I just finished making a complete backup to by NV unit and an external 5tb hard drive.
Now I inserted the new hard drive that failed after testing it and removing the partitions and the NAS resyncing one of the hard drives back into the fold. Once that is done I will do it for the next hard drive.
Once that is done I will re-start crashplan,(mdgm was great to move the cache out of the root) and see what is happening.
I am was running 4.7.0 and do not see any update for crashplan as of yet.
Anyway againg thank you so much mdgm & StephenB.
- sdouekOct 06, 2016Guide
UPDATE:
OK fnished back ups to external hard drives (2 sets)
re installed some add ons that were not behaving
emptied some more stuff out of my tmp driectory
initiated crashplan 4.7.0 and let it do its cache over again
Sucessfully backed via crashplan
Checked ".crashplan" and the Crashplan Cache is at 1.96 GB
ssh into box and did a df -h
Filesystem Size Used Avail Use% Mounted on /dev/md0 4.0G 1.5G 2.4G 39% / tmpfs 16K 0 16K 0% /USB /dev/c/c 7.3T 5.6T 1.7T 77% /c /c/dalbum 7.3T 5.6T 1.7T 77% /home/ftp/dalbum /c/library 7.3T 5.6T 1.7T 77% /home/ftp/library /c/publishing 7.3T 5.6T 1.7T 77% /home/ftp/publishing /c/transfers 7.3T 5.6T 1.7T 77% /home/ftp/transfers
Everything looks fine and the addons are behaving.
Thanks agiain
- StephenBOct 07, 2016Guru - Experienced User
I'm glad your back up again.
