sdouek
Sep 30, 2016Guide
Help with my readynas need support
OK so I have not been around for a while car accident. Any way I haven't been able to keep up on my readynas pro business edition. Thursday a hard drive failed. I put in a new one and it rebuild i...
- Oct 01, 2016
Your volume is not redundant (only four out of six disks in RAID-6)
/usr/local/crashplan is 2.8GB though. It has filled the 4GB root volume.
sdouek
Oct 06, 2016Guide
UPDATE:
OK fnished back ups to external hard drives (2 sets)
re installed some add ons that were not behaving
emptied some more stuff out of my tmp driectory
initiated crashplan 4.7.0 and let it do its cache over again
Sucessfully backed via crashplan
Checked ".crashplan" and the Crashplan Cache is at 1.96 GB
ssh into box and did a df -h
Filesystem Size Used Avail Use% Mounted on /dev/md0 4.0G 1.5G 2.4G 39% / tmpfs 16K 0 16K 0% /USB /dev/c/c 7.3T 5.6T 1.7T 77% /c /c/dalbum 7.3T 5.6T 1.7T 77% /home/ftp/dalbum /c/library 7.3T 5.6T 1.7T 77% /home/ftp/library /c/publishing 7.3T 5.6T 1.7T 77% /home/ftp/publishing /c/transfers 7.3T 5.6T 1.7T 77% /home/ftp/transfers
Everything looks fine and the addons are behaving.
Thanks agiain
Oct 07, 2016Guru - Experienced User
I'm glad your back up again.
