fearless_fool
Jan 19, 2014Aspirant
High Raw Read Error Rate: is it time to replace my drive?
The story: The last few times I powered up my ReadyNAS (following a shutdown), it found and corrected errors. But the last two times I've tried, it got stuck at 98% during File System Check. Th...
fearless_fool
Jan 20, 2014Aspirant
Very good. FWIW, according to http://www.ultimatebootcd.com/, Ultimate Boot CD ships with SeaTools already installed. (You may have meant this in your note, but it wasn't clear that this was the case.) Thanks for the tip.
