Mrx2003
Apr 03, 2016Aspirant
high temperatures on Readynas 3220 OS6.x.x
Hi guys,
i have an issue with the low fan speed (3xxx RPM) of the readynas 3220 and the extremly high HDD temperature at around 55°C. Before i used the 3200 version and my HDDs were on around 33°C (fan speed 5xxx RPM). Is there any possibility to manually reconfigurate the fanspeed? Any other ideas?
Best regards!
1 Reply
6.5.0 beta has some fan control settings, so that might be an option. If the max cooling setting isn't enough, you could provide some beta feedback.
