romahh12
Dec 06, 2021Aspirant
Home Folders disappeared after updating to 6.10.6
I have upgraded my ReadyNas to 6.10.6 to fix the issue with Antivirus, but after update the home folders went offline, and when I check home folders option, it shows "not shared". SMB Share is enable...
romahh12
Thanks for the reply,
I ran it, and yes, I can see the \home folder and all of its contents. I was also able to browse HomeFolder's contents using Nas admin page.
I should say that in the same NAS we have 3 other shared folders and they are working properly in the network.
Q- Should I back up only home folder contents or the entire NAS?
and what are the next steps to fix it.
Thanks and I appreciate your help.
romahh12
By the way when I try to access \\nas-IP-address, it shows me all the individual share folders for users (user home folders), but gives the error (you do not have permission to access). Looks like the issue is only with the home folders for each user due to their splicit permissions settings.
Does this give any idea?
- StephenBDec 07, 2021Guru - Experienced User
I don't know what happened during the upgrade.
There is a repair script you could try here: https://gitlab.codycook.us/readynas-scripts/share_lun_ui_fix.sh But it does require ssh access. Though I haven't seen any damage done with this script, it would be prudent to make a backup.
Another thing you can try is creating a new user, and then access the NAS using that user's credentials from File Explorer. If that creates an accessible home folder, then there is a workaround.
You can
- rename each user
- create a new user with the original username.
- log in as that user to create the home folder
- restore the contents
- delete the renamed user (which will delete the original data).
Note you could just delete/recreate each user and restore from backup, but renaming preserves the files, so is a bit more conservative.
mdgm or Sandshark might have other suggestions.
- SandsharkDec 07, 2021Sensei
I believe the repair script should do the trick. I've looked at what it does extensively (and learned a lot about the "back end" of ReadyNASOS in the process) and it does restore home folder permissions. Restoring a backed-up configuration file might also do it, as long as you have added no users since you backed it up.
