PATTERSON108's avatar
PATTERSON108
Home folders share not working for SMB
Hello all,   I have a ReadyNAS 102 with 2x 2tb raid setup as mirror. Firmware History 6.25 --> 6.40 ---> 6.50. I noticed there was a Share Called Home Folders. I have enabled SMB, FTP under the Acc...
  • StephenB's avatar
    Jun 01, 2016
    Inside home there is a subfolder for each user account.  When you using SMB, you log in as user X you will see the folder X - but not home itself. If you aren't seeing any user folder, then you are using guest (anonymous) credentials.  The solution is to go into windows credentials manager and enter the user account you want to use with the NAS.  You still won't see "home", just the private home share for that user.
    FTP works differently.  If you have FTP access for home shares, then you can see the home folder, but if you log in as user X and descend into it you will only see subfolder X, and not the others.
    Note that if you log in as admin, things work slightly differently with SMB.  Admin can access the full data volume using SMB - in which case you see everything including home.
ProSupport for Business
