cpu8088
Sep 08, 2015Virtuoso
Home Folders (special) what is it?
just wonder whats the use of this home folders can i have it hidden or deleted?
mdgm-ntgr
Sep 08, 2015NETGEAR Employee Retired
You can disable them.
Each user gets their own private home folder that only they and the admin user can access.
The private home folder is created when the user logs into SMB for the first time. They may need to logut and login again to see the newly created share.
- cpu8088Sep 08, 2015Virtuoso
thanks
but can it be deleted? or hidden?
- mdgm-ntgrSep 08, 2015NETGEAR Employee Retired
If you disable the private home shares then no more private home shares will be created and users won't be able to use them.
The entry on the web admin page. The web admin page is intended for administration.
