Ray2
Feb 20, 2023Luminary
Home folders visible in admin page but not accessible
Have two NAS's, both with 6.10.8. Running Win 10. Both have only one user---the admin--me.
The one I have been using the home folder for some time without issue.
The other one, I recently wanted to use the home folder but discovered that while I can see it on the admin page---I can't access to create any folders or upload a file to it? (Those choices are "grayed out").
I also notice that while the working one has a "admin" subfolder under the primary home folder, the one that does NOT work has no admin subfolder (nor will it let me create one). To the best of my knowledge both NAS's have similar protocols enabled and no other accounts/users.
The only difference I can discern is that the one that works was the one I was using for ReadyCloud, and the one that doesn't work was never set up for ReadyCloud.
Any thoughts on what's going on? Thank you in advance.
Normally the home folder itself will not show up in the shares list. Each user account on the NAS will have a shared folder inside "home". That is created the first time that user accessed the NAS using SMB with their account credentials. That will show up in the shares list when you access via Windows or Finder.
If you are seeing "home" in the share list for your other NAS, then you are accessing that NAS using its admin credentials (and the admin account is not using the default password). In that specific situation, you will see the full data volume in the share list, as well as "home".
Note that in that case, data\home\admin, \home\admin, and admin are just different paths to the same folder. That's also true for data\sharename and sharename.
- Ray2Luminary
Thank you for your reply, and I think I understand what you say, but I'm not sure I expressed my issue correctly?
The one NAS works exactly as expected.
The other NAS shows a home folder on the admin page, but does not show any subfolder for "admin". In other words, it doesn't seem to have been created the first time I accessed the NAS using SMB with my account credentials? Said another way, I have a 'data\home directory, but do not have a data\home\admin directory?
Is their a way to force its creation now that the NAS is in full use with other shares and data?
Did you ever access the NAS from a PC using the admin credentials? (using windows explorer, not your browser)?
Perhaps a bigger question - do you actually need that private folder?
