Inquiring_Minds
Sep 14, 2021Aspirant
Home Folders won't deploy for already created users
Model: ReadyNas 3220 Firmware: 6.10.5 Hotfix 1 Environment: Win10 20H2-21H1 | Domain I'm having an issue where after I've enabled Home Folders, already present user profiles on client machines ...
- Oct 01, 2021
OK, so mwilliams' personal folder is assigned to user 33397, which does not exist, and group 32897, which probably doesn't either.
drwx------ 1 33397 32897 0 Jan 30 2020 mwilliams
His proper user GUID is 33988 and his group is 33281:
uid=33988(mwilliams) gid=33281(domain users)
So I think chown -R mwilliams:33281 mwilliams from the .home share should fix the problem.
If not, then chown -R 33988:33281 mwilliams.
If the first one works, then this script should do it for all:
cd /home
for dir in */; do chown -R "${dir%?}:33281" "$dir"; done
chown -R admin:admin adminI'm using the GID for the group because I'm not entirely sure how to handle the group name "domain users" with a space in it.
If you have to use the UID instead of the name to make it work, then it'll take a lot more to get that info, and it's probably easier to just do it manually unless hou have a huge number of affected users.
Sandshark
Oct 01, 2021Sensei - Experienced User
cd /home
Inquiring_Minds
Oct 11, 2021Aspirant
Sorry, I replied to this but my reply just vanished, so here goes again.
The first line worked.
As for the "Domain Users" and as an example of what I did verbatim, I just ran:
id mwilliams
noted the gid of 33281(domain users), and ran:
chown -R mwilliams:33281 /home/DOMAIN/mwilliams
I will try the script after a bit.
Thank you so much for your time and patience.
