nickel22222
Jan 02, 2019Tutor
How and why to upgrade memory and cpu
How do I know I should upgrade memory or cpu?
It looks like only one dimm is in there, missing second.
STT DDR2 800 PC6400
2 GB?
What is the cpu? Is it logged? Reason to increase?
- Jan 02, 2019Verified I have e2160 1.8ghz per dmesg and 2gb per mem info.
So to confirm I can double memory and upgrade to e5300 2.6 ghz?
nickel22222
Jan 02, 2019Tutor
Sandshark
Jan 03, 2019Sensei
You can definately go with the upgrades you listed. Do check that you have the latest BIOS, though, before upgrading the processor.
Personally, I'd go all the way to the Core2 E7500. They are super cheap on eBay these days, and same TDP as the stock processor.
