ianch99
Aug 29, 2012Aspirant
How can I find out what is happening? (case #18901615)
My Duo v1 has been waiting in telnet mode since 21st Aug for L3 to try and get the NAS running again after it went AWOL when I tried to download the log files. I have asked a number of times for an up...
ianch99
Aug 31, 2012Aspirant
I have (external NTFS) backups but I had thought asking L3 to fix the problem would be quicker than a full restore. How wrong I was ...
Does anyone from Netgear read these posts? I have emailed the L2 contact again asking from an update. If he fails to reply tomorrow, I guess I have three choices?
1. boot and skip volume check
2. boot and do a os re-install
3. boot and do a factory default and full restore from backups
Any advice on which is best? I am guessing try in the order above i.e. 1, 2 and then 3 ...
