ianch99
Aug 29, 2012Aspirant
How can I find out what is happening? (case #18901615)
My Duo v1 has been waiting in telnet mode since 21st Aug for L3 to try and get the NAS running again after it went AWOL when I tried to download the log files. I have asked a number of times for an up...
Sep 01, 2012Guru - Experienced User
If your support contact is in the US, keep in mind that this is a holiday weekend, so their staffing is likely reduced. (Monday is "labor day" in the US).
ianch99 wrote: I have (external NTFS) backups but I had thought asking L3 to fix the problem would be quicker than a full restore. How wrong I was ...
Does anyone from Netgear read these posts? I have emailed the L2 contact again asking from an update. If he fails to reply tomorrow, I guess I have three choices?
1. boot and skip volume check
2. boot and do a os re-install
3. boot and do a factory default and full restore from backups
Any advice on which is best? I am guessing try in the order above i.e. 1, 2 and then 3 ...
I agree that skipping the volume check won't cure anything, though if you have data on the NAS that you need to get off, it might let you do that. Though you have a full backup. So if you really can't wait anymore, then (2) followed by (3) is reasonable.
