ianch99
Aug 29, 2012Aspirant
How can I find out what is happening? (case #18901615)
My Duo v1 has been waiting in telnet mode since 21st Aug for L3 to try and get the NAS running again after it went AWOL when I tried to download the log files. I have asked a number of times for an up...
PapaBear1
Sep 03, 2012Apprentice
Once you have recovered with an OS reinstall, it would be a great time to update/create your backup so you can then do a factory default. Apparently there is a problem with the size of the log file.
