ianch99
Aug 29, 2012Aspirant
How can I find out what is happening? (case #18901615)
My Duo v1 has been waiting in telnet mode since 21st Aug for L3 to try and get the NAS running again after it went AWOL when I tried to download the log files. I have asked a number of times for an up...
ianch99
Sep 04, 2012Aspirant
Thanks Dave. It is good to know that someone else out there has seen this. It did happen the last time I downloaded the logs but the Duo synced ok and cames back on-line. From memory, the boot partition was only ~50% full when I last looked so I do not believe it is a O/S partition full problem although I will check when I get it back on-line.
Latest update from NetGear Support: no L3 reponse as yet, Duo still in telnet mode waiting for them. The L2 Engineer cames back overnight with the less than helpful suggestion of:
I am struggling to see how I can upgrade the firmware when the Duo cannot boot ...
Thank you for your response. I do apologize for the inconvenience that this has caused you. Please upgrade your NAS firmware to the beta firmware 4.1.10[T3]. You may download the firmware on the link below:
viewtopic.php?f=17&t=59222
Thanks again for choosing NETGEAR. Have a great day!
