jimoe1
Jul 20, 2011Aspirant
How do I find how much memory the NAS has?
ReadyNAS-nv+
How do I find how much memory the NAS has? There is nothing in any of the admin menus.
- mdgm-ntgrNETGEAR Employee RetiredIt's stated on the homepage of Frontview (e.g. as seen in the simulator here: http://www.readynas.com/simulators/frontview/home.htm)
Stock memory for the NV+ is 256MB RAM (except for some models sold for a period of time which came with 1GB RAM). 256MB RAM is plenty.
3rd party memory upgrades are not supported. Incompatible memory can cause data corruption. Unfortunately memory manufacturers made changes to memory modules rendering them incompatible, but kept the same module number. Due to this NetGear was left with no choice but to remove the memory compatibility list. - jimoe1AspirantThanks.
(I don't know how I missed it; it's so obvious.) - jimoe1AspirantI decided to look into adding more memory to the ReadyNAS. Netgear makes this damn near impossible to do.
Can you provide a link to where Netgear hides the information about memory upgrades? And where to purchase it? - PapaBear1ApprenticeNetgear used to have an approved Hardware Compatibility List for memory, but the manufacturers of the memory modules had a nasty habit of changing the makeup of the modules without changing the model numbers. So the original versions worked but later versions did not.
I have a 7 year old HP laptop with a 1GB memory module that matches the original HCL and I installed it in my NV+. I really did not notice any difference because I used the NAS as a file server, and was not running any add on applications. When I needed the laptop again, I removed the 1GB module and replaced the original 256GB memory module. Even with the 1GB module in place, the sparc based CPU is still a limiting factor. The faster x-86 models with an Intel processor have a 1GB module standard. But then the processor is much faster also.
