robby99
Nov 23, 2012Aspirant
How identify between model versions NV+ v1 & NV+ v2
I am wanting to purchase an NV+ v2 however It is unclear what the manufacturer SKU is for the two models (v1 & v2). Sometimes they show a picture of a silver NV+ and sometimes they show a black model...
HERBIEO
Hi robby99
Going by that link you posted i presume you are in the Uk
Check this link http://www.dabs.com/products/netgear-re ... 0v2&src=16
and if you want it with Hard disks a good option would be to purchase a couple of the WD Reds to populate it which are on the HCL for NV+ v2 http://www.dabs.com/products/western-di ... ive&src=16
they allso do 1TB and 2TB versions
You could get that lot for £426.94 from Dabs which is a very good price.
