Redlikemethodz
Mar 16, 2025Guide
How loud is the ReadyNAS 3220???
I just got what I think is a killer deal on ebay for a 3220. The only worry I have is noise level. Someone on Reddit was complaining of noise and sold their's. The spec sheet says it only gets to 30db at 30c. Any feedback?
- SandsharkSensei
That's going to depend on how cool you keep the room and how much work the NAS is doing. The warmer the room (and the 3220 does create a fair amount of heat) and the more work it's doing, the faster the fans are going to run. During a RAID sync, scrub, or balance, the load will be higher and it's going to run louder. That 30dB is likely when the NAS is "at idle". I've got one that's a spare in case one of my other units fails, and it was noticeable that it was running when I was checking it out, but it wasn't as loud as my older RD5200 and RN4200V2 units. 30dB sounds like a pretty low volume compared to what I remember.
The small power supply fans are the biggest offender, mostly because they have a higher pitch. If you simply don't plug one in, you have to edit the config to keep the OS from complaining. You can pull one of them, but I don't remember if I still had to edit the configuration file to make the OS stop complaining about that (on the older units, pulling the supply was sufficient). I never found a blank to put in place of a supply, so you'd have to figure out what to use to cover the hole or just leave it in and loose.
Thank you for all the info!
