kipling100
Jan 14, 2012Aspirant
How to access readynas nv+ partition?
Hi, I have a hard drive that I used to use in my readynas nv+. I'd like to use that hard drive in my Windows 7 pc to transfer the data on there to another hard drive, but I can't seem to get access ...
mdgm-ntgr
Jan 16, 2012NETGEAR Employee Retired
Sounds like you'll need to power down the ReadyNAS, remove all disks (label order) and put the disk back in the ReadyNAS and recover the data that way. The far right disk is typically the parity disk and doesn't have the partition table on it.
