tigerten
Jul 01, 2023Luminary
How to backup desktop drive now that readycloud is gone?
Does any know of a way to back up desktop drive using Rsync or similar?
tigerten
Thanks StephenB Steph as always. the forum is so fortunate to have you and Sandshark keeing the legend going
Will give that a try.
There is cwRsync server which was discontinued and can still be found. Not sure How i can turn my PC into a Rsync server and back it up to Readynas.
Jul 02, 2023Guru - Experienced User
What you'd want is the PC to be an rsync client (since the NAS is the destination).
Personally I use Acronis TrueImage to make image backups of my PCs weekly to the NAS. That allows me to completely recover the PC (data and OS) if needed. That's not free though.
I also have some robocopy scripts that I run on some PCs.
- SandsharkJul 02, 2023Sensei
While I also use Acronis, I no longer recommend it to new users. The reasons are two-fold: It is now only available as a (high-priced, IMHO) subscription and the newest file format (which can be overridden with some "background" manipulation, but not in a straightforward way) is clearly intended to steer people to Acronis' own (also overpriced, IMHO) network storage. Storage solutions that are not "aware" of Acronis' method of tacking on changes to an existing file instead of creating separate incremental files as it used to can waste a lot of time and space because they see the entire file as new. It's been a while since I looked for alternatives, but the free version of AOMEI Backupper seemed to be a pretty good alternative when I did. A lot depends on whether you are looking for image backup (to restore after a hard drive crash, or even to a new computer) or file backup. Like Acronis, AOMEI can do both.
- StephenBJul 02, 2023Guru - Experienced User
FWIW, I am still using the old software. Likely I will look at switching on new PCs, though I'd like to stick with image backups.
- tigertenJul 02, 2023Luminary
I wanted a solution where I can sync my PC hard drive or folder with a readynas share, ideally two-way sync.
I also would like to operate this within the readynas backup tab, instead of from the PC. Does this sound like I need the PC to be a Rsync server?
I do not need to image my PC boot drive.
I guess you could try this:
Rsync can't do two-way sync, it only does one-way sync.
From what you said before, I concluded you wanted to backup up the PC to the NAS, not the other way around. Did I get this wrong?
One challenge here is how to handle the case when the PC isn't running. PC backup tools can power up the pc on a schedule, and then back it up to the NAS.
The NAS does have an option to use wake-on-lan before the backup starts, but I don't think the ReadyNAS implementation of WoL will work for wifi-connected PCs. Though I haven't tried to test that.
Thanks. I think I have the idea now.
yes, I am trying to backup PC to Readynas.
Good to know Rsync does not do two-way sync.
I think FreeFileSync might be the solution.
thanks a lot
