owensj
Apr 27, 2017Aspirant
How to change from JBOD to Raid1 on RN10200
How and where do I change the Raid level from JBOD to Raid1. All the othere RN10200 devices we have are set to that. This one is JBOD and it has disk 1 in blue and disk 2 in red, not being used. Also...
Apr 27, 2017Guru - Experienced User
Turn XRAID on (there should be a green stripe on the XRAID control if it is already on).
You might need to click on the red drive and then click format.
owensj
The XRAID does have a green stripe on it. If I click format on the red drive #2, will the NAS keep functioning, will it format and then sync? I am not familiar with what will happen and I don't want to wreck all the work I just did copying everything. I did not realize it wasn't turned on, simply being a newb and all.
