dishmagic66
Apr 26, 2014Guide
How to control fanspeed on a RN104
On special request, here is a workaround for controling the fanspeed of the RN104 ( most likely the same on a 102). For this you will have to SSH in to the NAS. Thanks to Moseleypj for doing the ...
Per_thomasl
Dec 07, 2016Aspirant
Hi!
I am new to linux and my ReadyNAS DUO FAN i is very loud and I want to try to adjust the fan speed. The built in calibration of the temperature fan do not work.
Can I use this script on a RND2000V1. It has an Infrant SPARC CPU, RADIator 4.1.15?
Thanks in advance
Thomas
