dishmagic66
Apr 26, 2014Guide
How to control fanspeed on a RN104
On special request, here is a workaround for controling the fanspeed of the RN104 ( most likely the same on a 102). For this you will have to SSH in to the NAS. Thanks to Moseleypj for doing the ...
saketb
May 31, 2014Aspirant
Finally got the error rectified. It was due to an extra character in the file.
I have changed the MAXTEMP=65 instead 75, so that the FAN spins a bit faster.
Now, the issue is when I issue the command...
service fanoveride start
I get the message...
root@ReadyNAS_RN104:/etc/init.d# service fanoveride start
Starting service.
Service started
Everything looks fine, but the FAN speed is yet 990, the temps remain same and not decreasing.
Surprising thing is that when I issue a command...
service fanoveride stop
root@ReadyNAS_RN104:/etc/init.d# service fanoveride stop
/etc/init.d/fanoveride: 29: kill: No such process
Service not running
This says that the Service is not running...
Request some guidance here.
Current temps...
CPU: 67 degC
HDD: 48-51 degC
FAN RPM: 990
Starting service.
Service started
Service not running
Current temps...
CPU: 67 degC
HDD: 48-51 degC
FAN RPM: 990
