dishmagic66
Apr 26, 2014Guide
How to control fanspeed on a RN104
On special request, here is a workaround for controling the fanspeed of the RN104 ( most likely the same on a 102). For this you will have to SSH in to the NAS. Thanks to Moseleypj for doing the ...
saketb
Jun 02, 2014Aspirant
townsmcp wrote:
saketb wrote:
townsmcp wrote: Woohoo - thanks guys - its now working for me :D
I tried Note++ and still got the same error message (saved the file as a *.* type) so went into Vi on a terminal (using the GateOne app) and as you guys said, the carriage return was being a problem - each line had ^M at the end so I deleted those and tried the steps again and all now working great - the fan spun up to 2500RPM within seconds using a max temp of 75. The service can be loaded and unloaded with no problems
Seriously thinking about changing max temp to 65 though (anyone have any thoughts on dropping the max temp that low?) - my NAS is tucked away in a room where the noise is of no bother to anyone - it now seems to be idling at the following rate:
Fan - 1241RPM
CPU - 53
Disk 1 - 37
Disk 2 - 39
Disk 3 - 40
Disk 4 - 37
(these are 2Tb WD Red drives)
Saketb - if you want I can email you over the 2 files that are working for me? That might help you
thanks all
Townsmcp
Its great to hear that its working for you and that the temps have come down considerably.
Mine, seems to not work and temps have risen to 70+ on the CPU. The service does not work.
Request you to email me the files so that I can copy them to the respective folders and start the service. (sent you a PM with my email)
One thing, I would like to ask... the files I created was with notepad++ and then deleted the ^M and saved them again in Vi.
When listed with ls -l it shows...
-rwxr-xr-x+ 1 guest guest 1799 May 31 19:20 fanoveride (root folder)
-rwxr-xr-x+ 1 guest guest 1317 May 31 20:02 fanoveride (/etc/init.d folder)
Are these correct? Is the guest guest correct? Is this why it is not running?
Request you to help me here, as I'm really worried about the temps and the device.
Thanks.
Will send the files in a few minutes.
That guest guest thing is probably the issue. My files are there by root root. I would suggest the following:
1. Install Bitvise SSH Client (from http://www.bitvise.com/download-area).
2. Load SSH Client and log into the NAS with the Root account (using root as the username and your NAS password as the password)
3. Drag and drop the files I send you to correct directories.
4. Right click the files and change permissions to 755
5. Run the update-rc.d fanoveride defaults command
6. Start the service
7. Check the admin page to see if the page has changed speed
8. Try stopping the service to make sure it unloads ok (remember to restart it too though ;) )
Let us know if that works for you.
Townsmcp
Thanks a million. Finally, got it working.
Used Putty for ssh access and transferred the files. Changed the MAXTEMP to 65 and now the temps have come down drastically.
FAN RPM 1706
CPU 53-56C
HDD1 42C
HDD2 43C
HDD3 41C
Though, the files yet show guest, guest. Thats surprising....
Thanks again for the help.
