dishmagic66
Apr 26, 2014Guide
How to control fanspeed on a RN104
On special request, here is a workaround for controling the fanspeed of the RN104 ( most likely the same on a 102). For this you will have to SSH in to the NAS. Thanks to Moseleypj for doing the ...
analog1
Nov 11, 2014Aspirant
Thanks for great info. Just added fanoveride and temps are better now. Fanspeed is around 1500 rpm during rebuild. CPU temp 50 C and drives around 40 C. Temps were before CPU 65 - 70 C and drives near 50 C and fanspped around 800 rpm.
It would make sense for Netgear to add these fan profile adjustments in to readycloud GUI, so that users could select suitable profile for their use based on environment temperature and other factors.
