dishmagic66
Apr 26, 2014Guide
How to control fanspeed on a RN104
On special request, here is a workaround for controling the fanspeed of the RN104 ( most likely the same on a 102). For this you will have to SSH in to the NAS. Thanks to Moseleypj for doing the ...
AndreasKa
Jan 13, 2015Tutor
Hi all,
I recently setup my new 314 and attempted to use this script but it doesn't seem to be working. The fan stays 730-780 rpm with temps as follows:
Fan - 750RPM
CPU - 53
system - 39
Disk 1 - 43
Disk 2 - 41
Disk 3 - 45
Disk 4 - 48
This is without any activity at all, just the disks spinning, not in a volume.
I'm wondering if anyone has implemented this successfully on a 314 because i'm not getting any errors and the service seems to be starting.
I've also tried changing the min and max temp to 40 and 60 respectively but still no change.
any help much appreciated
Fan - 750RPM
CPU - 53
system - 39
Disk 1 - 43
Disk 2 - 41
Disk 3 - 45
Disk 4 - 48
