dishmagic66
Apr 26, 2014Guide
How to control fanspeed on a RN104
On special request, here is a workaround for controling the fanspeed of the RN104 ( most likely the same on a 102). For this you will have to SSH in to the NAS. Thanks to Moseleypj for doing the ...
AndreasKa
Jan 15, 2015Tutor
Hi All,
Not sure if anyone is interested but I had a look at the logs for this from my 314 and it's now obvious to me why it's not working but not so obvious as to the fix. If anyone is interested in getting more info, reply to the thread.
Automatically controlling fan speed...
cat: /sys/devices/platform/mv64xxx_i2c.0/i2c-0/0-003e/pwm1: No such file or directory
cat: /sys/devices/platform/mv64xxx_i2c.0/i2c-0/0-003e/fan1_input: No such file or directory
cat: /sys/devices/platform/axp-temp.0/temp1_input: No such file or directory
Temp: C FAN: 50% [ RPM] []
expr: syntax error
expr: syntax error
expr: syntax error
/root/fanoveride: line 21: [: -lt: unary operator expected
/root/fanoveride: line 24: [: -gt: unary operator expected
expr: syntax error
expr: syntax error
