dishmagic66
Apr 26, 2014Guide
How to control fanspeed on a RN104
On special request, here is a workaround for controling the fanspeed of the RN104 ( most likely the same on a 102). For this you will have to SSH in to the NAS. Thanks to Moseleypj for doing the ...
ARay
Apr 15, 2015Aspirant
I figured out that when I copied the script into notepad++ or vi, it was giving extra spaces at the beginning of each line. After I took those out, I now get no errors, and it says the service is started, but fan still shows as hanging out at 800 RPM. Any suggestions on where to look when it looks like it should be "on"?
I had been on 6.3.3-T153 beta, so I went back to 6.2.2 to see if the beta was an issue and that put my fan speeds in the 680s range...
