dishmagic66
Apr 26, 2014Guide
How to control fanspeed on a RN104
On special request, here is a workaround for controling the fanspeed of the RN104 ( most likely the same on a 102). For this you will have to SSH in to the NAS. Thanks to Moseleypj for doing the ...
tiff_lee
Apr 28, 2015Tutor
Hi all hopefully someone can help me out here, trying to use this guide in order to get some 'better' fan control on my RN104 but struggling a little bit, SSH and linux commands are all new to me.
Created the two files as per the first post (using notepad++ but what file format am I supposed to save them in, .sh? or are they not meant to have a file extension at all) and put them in the appropriate location using Bitvise SFTP.
Once i've changed the properties value to 755 and run the "update-rc.d fanoveride defaults" I receive an error "insserv: warning: script 'leafp2p' missing LSB tags and overrides" ?
I appear to be missing something here and it will probably be obvious to the more experienced people out there, pointers appreciated.
Lee
Lee
