dishmagic66
Apr 26, 2014Guide
How to control fanspeed on a RN104
On special request, here is a workaround for controling the fanspeed of the RN104 ( most likely the same on a 102). For this you will have to SSH in to the NAS. Thanks to Moseleypj for doing the ...
booboo59
Apr 28, 2015Apprentice
Thank you note to the OP, the scripts work well on my RN104. Only change would be that the +755 needs to be just 755. Other than that, the instructions are spot on!
