dishmagic66
Apr 26, 2014Guide
How to control fanspeed on a RN104
On special request, here is a workaround for controling the fanspeed of the RN104 ( most likely the same on a 102). For this you will have to SSH in to the NAS. Thanks to Moseleypj for doing the ...
mdgm-ntgr
May 24, 2015NETGEAR Employee Retired
With notepad++ you do need to be using the correct formatting options for copy and paste into that to work well or to open a script that is already formatted correctly.
