dishmagic66
Apr 26, 2014Guide
How to control fanspeed on a RN104
On special request, here is a workaround for controling the fanspeed of the RN104 ( most likely the same on a 102). For this you will have to SSH in to the NAS. Thanks to Moseleypj for doing the ...
Aguster
Jul 30, 2015Initiate
Followed the instructions to a T. Installed fine, with only one error shown below.
With the exception of changing "retart" to "restart" and no "+" in "chmod +755 /etc/init.d/fanoveride". Service starts but no change in fan speed. Anyone else having this issue on 6.2.x (i'm running 6.2.4).
Oh, I actually did get one error on: "update-rc.d fanoveride defaults"
LSB issue on leafp2p. Change /etc/init.d/leafp2p
insserv: warning: script 'leafp2p' missing LSB tags and overrides
insserv: There is a loop between service logitechmediaserver and leafp2p if stopped
insserv: loop involving service leafp2p at depth 2
insserv: loop involving service logitechmediaserver at depth 1
insserv: Stopping leafp2p depends on logitechmediaserver and therefore on system facility `$all' which can not be true!
insserv: exiting now without changing boot order!
update-rc.d: error: insserv rejected the script header
Also posted over here: https://community.netgear.com/t5/Using-your-ReadyNAS/LSB-issue-on-leafp2p/td-p/929396
