brais32
Jan 17, 2014Aspirant
How to deal with end-of-life hard drives?
Our Readynas3200 came with Seagate ST2000NM0011 hard drives. We would like to expand the storage capacity on this storage unit but discovered that these hard drives are end-of-life. I'm use to work...
Jan 17, 2014Guru - Experienced User
You can mix and match. You do need to use the same size (or larger), so check the datasheet for the number of sectors (as well as checking the HCL).
