denaus50
Sep 24, 2016Aspirant
How to download torrent files onto the RN10400
I am totally new to NAS. I am used to downloading video direct to my pc and extedened HD. But I really need help in how to download directly onto my RN10400. It houses 2. 4gb WD Reds. I can't seem t...
JennC
Sep 24, 2016NETGEAR Employee Retired
Hello denaus50,
Are you trying to get movies downloaded and stored to the NAS from via torrent client? ReadyNAS has some torrent client apps such Qbittorrent and Utorrent that you can use to download movies.
Welcome to the community!
denaus50
Sep 25, 2016Aspirant
Hi JennC
Thank you so much for responding.
Yes, that is what I'm wanting to do. If I use Utorrent, will that dowload the file (.mkv etc) as is so I can then stream direct to my TV. Basically I need to have a "how to" for downloading and for streaming.
I am used to downloading to my pc and then transferring onto portable HD and playing through my AC Ryan media player connected to my smart tv.
Thanks again!
DenAus
- StephenBSep 25, 2016Guru - Experienced User
Is this one of their android players? Perhaps let us know the model.
- denaus50Sep 25, 2016Aspirant
Hi StephenB
As I have a smart TV with DLNA, I am hoping to use the 10400 to stream instead of using the AC Ryan (which isn't android)
Thanks
Denaus50
There are two DLNA options. ReadyDLNA is built in, so you can just enable it on a media share and see how it works with the TV.
Plex is also available, you download it from plex.tv and install it on NAS through the settings->manual install control.
