SWhetsel
Jan 24, 2011Aspirant
How to install Joomla on ReadyNAS - Walkthrough
To install Joomla 1.5 on the ReadyNAS, you’ll need to do the following. (detailed steps below) 1. Create a share on the ReadyNAS where you will run Joomla 1.5 and enable Internet access to the sha...
SWhetsel
Jan 07, 2012Aspirant
lagen wrote: I success to install Joomla on my readynas.
in front I login to this address: 192.168.1.200/website
but when I try back end 192.168.1.200/website/administrator then I get a file browser.
I get "Hypertext Transfer Protocol" only work on this map(192.168.1.200/website)
so when I try this map(192.168.1.200/website/administrator) file browser show.
someone have know about this problem I have?
It is case sensitive. Make sure you are typing it exactly as you have it saved.
