SWhetsel
Jan 24, 2011Aspirant
How to install Joomla on ReadyNAS - Walkthrough
To install Joomla 1.5 on the ReadyNAS, you’ll need to do the following. (detailed steps below) 1. Create a share on the ReadyNAS where you will run Joomla 1.5 and enable Internet access to the sha...
landolas
Jun 03, 2012Aspirant
Hi,
First - thanks very much for this posting - worked through it and had a lot of fun testing websites before publishing. I'm also now using Joomla! 2.5 on a windows desktop which I installed using http://docs.joomla.org/Use_Joomla!_on_your_own_computer and need to upgrade Joomla! 1.5 to 2.5 on the ReadyNAS. I copied across XAMPP to a new share on the ReadyNAS after setting this up as a personal server as per your instructionss but so far I haven't felt confident enough to actually run this on the ReadyNAS Duo (as I did on the desktop) since I'm not convinced it will work and I equally don't want to blow away my working Joomla! 1.5 environment on the ReadyNAS. Any suggestions as to the best way to upgrade from Joomla! 1.5 to 2.5 on the ReadyNAS - or I would be more than happy to simply do a full install of 2.5 but without using something like XAMPP, I suspect it could be a longhaul manually upgrading PHP and MySQL first. Any help with this greatly appreciated.
