SWhetsel
Jan 24, 2011Aspirant
How to install Joomla on ReadyNAS - Walkthrough
To install Joomla 1.5 on the ReadyNAS, you’ll need to do the following. (detailed steps below) 1. Create a share on the ReadyNAS where you will run Joomla 1.5 and enable Internet access to the sha...
SWhetsel
Jun 04, 2012Aspirant
Try this for the upgrade.
http://extensions.joomla.org/extensions ... tion/11658
With anything though, make backups in case it doesnt work.
