SWhetsel
Jan 24, 2011Aspirant
How to install Joomla on ReadyNAS - Walkthrough
To install Joomla 1.5 on the ReadyNAS, you’ll need to do the following. (detailed steps below) 1. Create a share on the ReadyNAS where you will run Joomla 1.5 and enable Internet access to the sha...
pugilares
Jun 06, 2012Aspirant
In reply to that I get
Enter password:
I hit Enter key and then I get
mysqladmin: connect to server at 'localhost' failed
error: 'Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)'
Check that mysqld is running and that the socket: '/var/run/mysqld/mysqld.sock' exists!
Enter password:
