SWhetsel
Jan 24, 2011Aspirant
How to install Joomla on ReadyNAS - Walkthrough
To install Joomla 1.5 on the ReadyNAS, you’ll need to do the following. (detailed steps below) 1. Create a share on the ReadyNAS where you will run Joomla 1.5 and enable Internet access to the sha...
pugilares
Jun 07, 2012Aspirant
I un-commented bind-address = 127.0.0.1
Then I do
nas-XX-XX-XX:/etc/mysql# mysqld
120607 9:32:02 InnoDB: Started; log sequence number 0 43655
120607 9:32:02 [Note] mysqld: ready for connections.
Version: '5.0.24a-Debian_3.infrant1' socket: '/var/run/mysqld/mysqld.sock' port: 3306 Infrant ReadyNAS distribution
I have no prompt further. So I have to login with another ssh session as root and do
mysqladmin shutdown
to regain prompt at the original session.
I also rebooted the whole box and checked it again with the same result.
Then I do
mysqladmin shutdown
