SWhetsel
Jan 24, 2011Aspirant
How to install Joomla on ReadyNAS - Walkthrough
To install Joomla 1.5 on the ReadyNAS, you’ll need to do the following. (detailed steps below) 1. Create a share on the ReadyNAS where you will run Joomla 1.5 and enable Internet access to the sha...
kraeks
Jun 08, 2012Aspirant
I'm not sure exactly. Have you installed mysqld from apt-get? That is a requirement. Would you mind trying this:
after that you SHOULD have an init.d-script for mysql.
Cheers.
sudo apt-get purge php5-mysql
sudo apt-get install mysql-server
sudo apt-get install php5-mysql
Cheers.
