SWhetsel
Jan 24, 2011Aspirant
How to install Joomla on ReadyNAS - Walkthrough
To install Joomla 1.5 on the ReadyNAS, you’ll need to do the following. (detailed steps below) 1. Create a share on the ReadyNAS where you will run Joomla 1.5 and enable Internet access to the sha...
kraeks
Jun 08, 2012Aspirant
Another, probably better approach is if you follow my guide at viewtopic.php?f=11&t=63591 which is a bit newbie friendlier and offers a solution that's a bit more all around. Then continue with http://docs.joomla.org/Installation - which is also straight forward and good.
