SWhetsel
Jan 24, 2011Aspirant
How to install Joomla on ReadyNAS - Walkthrough
To install Joomla 1.5 on the ReadyNAS, you’ll need to do the following. (detailed steps below) 1. Create a share on the ReadyNAS where you will run Joomla 1.5 and enable Internet access to the sha...
pugilares
Jun 08, 2012Aspirant
nas-xx-xx-xx:/etc/init.d# apt-get install mysql-server
Reading Package Lists... Done
Building Dependency Tree... Done
The following extra packages will be installed:
libdbd-mysql-perl libdbi-perl libmysqlclient12 libnet-daemon-perl libplrpc-perl mysql-client
Suggested packages:
dbishell libcompress-zlib-perl mysql-doc
The following packages will be REMOVED:
mysql-client-5.0 mysql-server-5.0 squeezecenter-readynas
The following NEW packages will be installed:
libdbd-mysql-perl libdbi-perl libmysqlclient12 libnet-daemon-perl libplrpc-perl mysql-client mysql-server
0 upgraded, 7 newly installed, 3 to remove and 71 not upgraded.
Need to get 5377kB of archives.
After unpacking 40.7MB disk space will be freed.
Do you want to continue? [Y/n]
All right - so this will remove sqeezecenter server from my box? I don't use it now, but I may need this one day.
Should I say Y or n??? :-)
Suggested packages:
