SWhetsel
Jan 24, 2011Aspirant
How to install Joomla on ReadyNAS - Walkthrough
To install Joomla 1.5 on the ReadyNAS, you’ll need to do the following. (detailed steps below) 1. Create a share on the ReadyNAS where you will run Joomla 1.5 and enable Internet access to the sha...
pugilares
Jun 09, 2012Aspirant
So joomla 1.5 seems to work on my Duo now :-)
The database "page" created this way as above is located on the system partition of the ReadyNAS, isn't it? Where the actual data of this database will be stored? I would prefer to store data on website share rather then on the system partition.
